hand through a screen grading change
Ben Thoume
on Mar 7, 2019 at 4:05:02 pm
I was hoping to create an effect where a persons hand reaches forward out of a computer screen,
I am fine with rotoscoping the hand etc but to sell the effect better I wanted to change the grading on the hand as it comes forward, so is there an easy way to create like a plain/film over the screen area which the hand can pass through forward,
I know this would be easy if the hand was going to the left or right as I could use a simple mask but as the hand is coming forward is there an easier way than key framing a mask path on the hand frame by frame
Thanks in advance
Kalleheikki Kannisto
Re: hand through a screen grading change
on Mar 7, 2019 at 4:51:37 pm
3D animating the hand instead of shooting it comes to mind as an "easier" solution. That way you can create the screen from a semi-transparent material. The exact meaning of "easier" in that sentence depends on your experience with such.
Senior Graphic Designer
Dave LaRonde
on Mar 8, 2019 at 5:18:04 am
You could shoot a real hand and use some precise lighting. That too sounds pretty simple.
Dave LaRonde
Promotion Producer
