After Effects Crashes When Opening Project
Nicholas Harris
on Mar 7, 2019 at 2:47:49 am
Hi again. I've been having an issue with another project. Whenever I try to open the project, AE freezes and crashes. I really don't want to redo everything so any help is appreciated. I use CS6.
I've tried:
Restarting the computer
Importing the Project
Opening with Caps-Lock on
Clearing cache
Updating Drivers
None of these worked.
Anders Hattne
Re: After Effects Crashes When Opening Project
on Mar 7, 2019 at 10:15:47 am
Hello,
Try opening After Effects. Then go File>Open.
When you select the project file, hold down SHIFT. That way the project will open without opening any Compositions.
You can also use Caps Lock to open Comps, and turn off all layer visibilities.
Then you can go through the project until you find the comp / layer that causes the crash.
Sometimes I've had problems with certain keyframes on masks!!
http://www.ardillamedia.com
Nicholas Harris
on Mar 7, 2019 at 9:33:59 pm
This method doesn't work. After Effects crashes before I even get to see the project. It crashes while loading, in other words.
Anders Hattne
on Mar 8, 2019 at 10:00:33 am
...in that case.. How about opening one of your previous versions from the Auto-Save Folder before it started crashing?
Richard Garabedain
on Mar 8, 2019 at 5:07:24 pm
have you tried closing after effects and then Opening the project directly from its save file? this sometimes helps
