Is there a way to fix/improve footage with dropped frames?
Adi Frank
on Mar 3, 2019 at 4:39:33 pm
Hi all,
During a documentary-style shoot, I failed to notice the memory card was pretty full before starting to shoot what turned out to be a fairly long shot. This resulted in the shot consisting of scattered dropped frames. To make matters worse, it was one of those shots that you can't re-shoot. The general style of this project is kind of wonky from a technical aspect, meaning out-of-focus, bad lighting, shaky footage — it's all fine. But the dropped frames are a bit too much. Is there any way in After Effects to somehow smooth over the dropped frames so that it's a bit less "jumpy"? I read something online about somehow fabricating an in-between frame to insert where the frame/s dropped, but I gathered from the article that it was talking about a situation where the camera is static and there's not much going on as far as motion in the frame (like a talking head). In my case, unfortunately, it's hand-held camera. Not a whole lot going on in the shot — a family sitting around a dinner table talking — but there definitely is camera movement.
Does anyone have any experience or 2nd hand knowledge on how to fix or at least improve footage with dropped frames?
Chris Wright
Re: Is there a way to fix/improve footage with dropped frames?
on Mar 3, 2019 at 6:22:25 pm
https://aescripts.com/pt_framerestorer/
or use timewarp yourself
Kalleheikki Kannisto
on Mar 3, 2019 at 6:26:03 pm
If it is just a few frames each time, you can use Twixtor to generate the in-between frames. You will have to insert the frames manually into the right spots. It is slow and largely manual procedure.
Some discussion of this approach here:
https://forum.videohelp.com/threads/366259-Twixtor-to-help-invent-frames
Senior Graphic Designer
