A script with a viewer
Ahmed Mabrouk
on Mar 1, 2019 at 8:49:54 pm
I'm planning to create a script to control a project template i'm working on, a script UI integrated with a preview of the animation before being applied, so i thought about rendering the animation and exporting it as SWF then use flashplayer in the script, but what if i wanted to make the preview responsive to edits that can be made by the script (like changing the color of something), in what code should be my animation?
Dave LaRonde
Re: A script with a viewer
on Mar 2, 2019 at 12:07:45 am
Code that says, "render the animation over again and export over again". You can figure out whether you want the new animation to write over the old one or give it a different name if you want to save the old one.
Dave LaRonde
Promotion Producer
