Automatic Z-Depth from JPG?
Lucas Schwartz
on Feb 24, 2019 at 5:57:59 pm
Hello All,
I was just wondering if there is such a software exists that can create an automatic Z-Depth map from a common JPG please?
If there is no such software currently available on the market what would be the easiest way to quickly create complex z-depth maps from 2d images?
Best regards,
Lucas
Mark Whitney
Re: Automatic Z-Depth from JPG?
on Feb 24, 2019 at 11:40:54 pm
Yes, but not for sequences at least yet. Not particularly easy to find either as it's just one aspect of a plug-in for Photoshop and Affinity called Tapaz Labs Lens Effects
https://topazlabs.com/lens-effects/
They also make Topaz Studio just to confuse things initially. Some of their products are stand-alones, some are plug-ins, & some just for Studio with crossover versions from the others. Got that?
Anyway, in Lens Effects, they've a Bokeh Lab.
Take a look at these vids & it'll make sense.
https://www.youtube.com/user/topazlabs/search?query=Lens+Effects
Main point is, you can export the resulting depth map.
Lucas Schwartz
on Feb 28, 2019 at 10:38:29 am
Hello Sir,
Thank you for your response. I have spent a long time looking for a solution to create automatic depth maps. The suggested "Topaz lab solution" will work really well. I also have had it installed as a photoshop plugin already.
I just watched the suggested tutorial also which was helpful to explain how to use the plugin.
Once more thank you for the excellent tip!
Best regards,
Lucas
