Adding Gaps to Shape Layer Stroke Dashes
Jordan Hull
on Feb 22, 2019 at 1:35:40 am
I am wondering if it is possible to add "Gaps" to shape layer stroke dashes.
I can clearly see "Dashes" and can achieve the result on the top of attached image.
I'm hoping to achieve the result on the bottom of the attached image.
Thanks in advance.
Greg Gesch
Re: Adding Gaps to Shape Layer Stroke Dashes
on Feb 22, 2019 at 3:25:50 am
Hi. Press the + again and you will get a Gap spacer heading.
Jordan Hull
on Feb 22, 2019 at 5:44:27 pm
Solved!
Thank you, that was easier than i thought.
