Search for Layer Name
Björn Sieck
on Feb 21, 2019 at 10:26:58 am
Hello,
I'm working on projekts with maps and there are several hundreds of layers, named with citys, oceans, countrys...
Is there any way to search for a specific layer name? Maybe by a script? I searched but I can't find something.
Thanks for help!
Walter Soyka
Re: Search for Layer Name
on Feb 21, 2019 at 10:33:39 am
The comp window has a search box that's very easy to overlook:
[image]
Is that what you're looking for?
Walter Soyka
Björn Sieck
on Feb 21, 2019 at 10:38:26 am
No, that is not what I'm looking for. Sorry.
I'm searching for something where I can type the name of the layer, for example "Atlantik Ocean" and the layer will be markt and shown.
Walter Soyka
on Feb 21, 2019 at 10:44:06 am
Perhaps I don't understand your request, but the comp search box will do exactly that. For example:
Before search:
After search:
Walter Soyka
Björn Sieck
on Feb 21, 2019 at 10:46:53 am
Hmmm, when I try this nothing happened.
Björn Sieck
on Feb 21, 2019 at 10:48:34 am
I also tried it before, the same thing.
Walter Soyka
on Feb 21, 2019 at 10:52:31 am
Make sure you clear your layer selection first. If you have layers selected, the search box will search within the selection and hide anything that doesn't match, but it will leave all unselected layers visible.
Walter Soyka
Björn Sieck
on Feb 21, 2019 at 10:59:47 am
OK, found the problem, usermistake. I always have a layer selectet, that would not work.
But is there a way, that not only the layer is shown? I also like to see all the other layers, so i cant jump to the layer and work with that and the other layers.
Example: I search for a layer with a country name, the layer will be markt and i can select this layer and all the layers that are under that layer with city names.
Hope I explained it clear.
Walter Soyka
on Feb 21, 2019 at 11:09:05 am
Try this: Enter your search term. Select the layer you wish from the results. Clear the search. Press the X key to scroll the timeline panel to the selected layer.
Walter Soyka
Björn Sieck
on Feb 21, 2019 at 11:18:01 am
Thats it! Thank you very much. That saves a lot off time!
Walter Soyka
on Feb 21, 2019 at 11:20:11 am
You're welcome! Good luck with your project.
Walter Soyka
