Footage with alpha channel but no luma matte
Martin McHugh
on Feb 13, 2019 at 10:57:07 am
Please help before I go crazy. I bought some footage from shutterstock which said it had alpha channel. So I presumed bg was transparent and I could just drop into ae.
But it just sits there with black bg. I can’t see image underneath. It didn’t have a luma matte with it and I can’t use any colour clipping as footage has lots of black too.
I’m sure there is just magic secret button I am missing? Pls help!
Bouke Vahl
Re: Footage with alpha channel but no luma matte
on Feb 13, 2019 at 1:31:19 pm
what do the properties say?
It can have an alpha that is a solid, so it is there, but does nothing.
Bouke
http://www.videotoolshed.com
Tomas Bumbulevičius
on Feb 13, 2019 at 1:32:38 pm
Martin,
once footage is imported, in the project panel:
1. Right click and select Interpret Footage > Main...
2. See if its set to Straight.
Hopefully its not yet and you will be able to recover it easily (:
Find out more:
After Effects Tutorials: motion design, expressions, scripting.
Martin McHugh
on Feb 13, 2019 at 5:57:16 pm
Thanks guys for taking time to reply.
Under interpret - main all the top section to do with alpha is greyed out. ?? You can’t select any of it?
Dave LaRonde
on Feb 13, 2019 at 5:26:15 pm
I hope you checked the clip's head & tail for both matte & fill on the same clip, one following the other.
Dave LaRonde
Promotion Producer
Martin McHugh
on Feb 13, 2019 at 6:03:15 pm
Yeh been through the clip loads of times there’s nothing there apart from black bg one.
Dave LaRonde
on Feb 13, 2019 at 11:45:09 pm
Well, all I can think of is that you got the wrong clip or you didn't get the luma matte clip.
Dave LaRonde
Promotion Producer
Daniel Waldron
on Feb 14, 2019 at 2:16:30 pm
What is the clip of? Sometime stock sellers will say it has an alpha channel, when really they expect the editor to change the transfer mode to Screen or Add. I've seen this with dust, fire, etc. It sounds like that may not be an option for you, so you may want to contact Shutterstock and request a refund.
Damien Ivan
on Feb 14, 2019 at 8:07:33 pm
That's pretty lame if it doesn't have an actual alpha, but as a workaround, maybe Unmult will work?
https://support.redgiant.com/hc/en-us/articles/360010345194-Where-can-I-get...
Damien Ivan
Animation + Video
Just a dude tryin to be awesome.
damienivan.com
Martin McHugh
on Feb 14, 2019 at 8:14:46 pm
Thanks so much for your replies. I tried screen and add but they effect the footage too much. Also no joy with demult. Shutterstock have now said alpha is only be available on hd footage not the sd? It doesn’t tell you that anywhere and it sounds odd to me as what is the point of the sd then??
I’m sure I’m just doing something really dumb.
