Question about displacement map
kawin tisase
on Feb 12, 2019 at 7:02:19 pm
Firstly my composition is 1920*1080 and I use AECC 2015
This is my base layer
This is my displacement map
when I use displacement map and crank the value up to around -4000 .I can still see the white line , that is my base layer, around the displacement map, NOTE : turning off simple choker did not cause white line to dis appear
The question is, Why is there a white line around displacement map. Is there any in-depth expalnation to this. Not to be confused, I want white line around displacement map. I just curious. I tired reading this article https://library.creativecow.net/articles/hodgetts_philip/displacement.php and listen to this tutorial https://library.creativecow.net/video_page.php?author_folder=rabinowitz_aha...
but no answer came
Thank you in advance for answering me xD.
Richard Garabedain
Re: Question about displacement map
on Feb 12, 2019 at 8:53:54 pm
i always get the white lines if my displacement is too high...maybe if you used a simpler layer to displace..
Max Haller
on Feb 12, 2019 at 10:13:44 pm
Thats just what happens when you displace the layer so much. its like smeared to the edges of the displacement map. What are you trying to displace?
Damien Ivan
on Feb 14, 2019 at 8:45:11 pm
Since the displacement map is black and white and has no alpha, you can't use choke matte on it without some effects gymnastics. Otherwise, I don't totally understand what you're saying in your question.
Damien Ivan
Animation + Video
Just a dude tryin to be awesome.
damienivan.com
Oleg Pirogov
on Feb 14, 2019 at 11:58:26 pm
Not really familiar with this effect, but as far as I know, it displaces pixels of base layer based on brightness (I assume, you use that kinde of mode) of map layer. The most bright moves one direction, the most dark - to the other, while pixels close to medium brightness don't move a lot.
Thus, at -4000 everything but pixels really close to medium brightness has moved away. I presume, if you check the color of those white pixels on the map, they would be [128, 128, 128] color or something.
Here's a shape filled with strictly horizontal gradient moving a solid with fractal noise. When increasing Max Vertical Displacement, the dynamics are quite simple:
All white goes max up, all black goes max down, medium things fall in between.
At extreme levels the only pixels visible on the comp will be those near the center of grad:
So I suppose, those lines of yours are areas of constant color=[128, 128, 128]. They look like lines due to the nature of your map, but generally can be whatever. For instance, here is a circle of [128, 128, 128] color added to that +5000 Max Vertical Displacement setup above:
kawin tisase
on Mar 9, 2019 at 3:18:52 pm
Wow, your answer really helped me with my curiosity. Thanks a you mr Oleg, have a nice day ☺
