Outputting frame sequence but only every Nth frame
Robert Newton
on Feb 8, 2019 at 8:13:32 pm
I'm creating photogrammetry derived models from drone footage. The software I use to create the models works from frame sequences. Only it does not need the thousands of frames created when I spit out a frame sequence from AE based on the original video from the drone. I really only need around every 100th frame in that sequence.
I've worked out a very time-consuming, laborious way to get this done, but I keep thinking this has to be a simple render script in AE that tells AE to only render every 100th frame (Nth frame). Number sequencing is irrelevant to my software.
Any ideas would be helpful, thanks.
Robert
