Motion Tile Phase Question
Jacob Roth
on Feb 5, 2019 at 4:14:14 pm
I'm creating a motion background, and I have a comp with a single logo in it. I've applied Motion Tile said comp multiply the logo into columns. By turning the phase angle control I can get every other column to scroll past, but I'd like the currently stationary columns to scroll in the opposite direction.
Any ideas?
Richard Garabedain
Re: Motion Tile Phase Question
on Feb 5, 2019 at 8:47:03 pm
Motion tiles options are pretty limited. i would do it another way
Greg Gesch
on Feb 6, 2019 at 12:41:28 am
Hi, you could try precomposing two versions (1 going up, 1 going down). Mask out and subtract the still columns in your main comp, and then offset the X position of the one that needs the fewer rows(?).
Jacob Roth
on Feb 6, 2019 at 2:28:39 pm
Thanks everybody.
What I ended up doing was creating one column through the motion tile width setting, then duplicating that comp as many times as I needed. Then I made a control layer for odds, one for evens, and then phase got time*x or -x depending on odd or even. It worked, but was a pretty heavy render.
