Recreate Effect
Chris Barnes
Recreate Effect
on Feb 4, 2019 at 8:02:55 pm
I need to recreate this wave bulge effect at the start of the following video.
https://vimeo.com/user21238398/review/315304763/e64ff318a7
Any help will be greatly appreciated.
Kalleheikki Kannisto
Re: Recreate Effect
on Feb 4, 2019 at 8:10:25 pm
Link goes nowhere.
Senior Graphic Designer
Chris Barnes
Re: Recreate Effect
on Feb 4, 2019 at 8:30:59 pm
My mistake. Here is the correct link.
Richard Garabedain
Re: Recreate Effect
on Feb 4, 2019 at 9:57:17 pm
really? 1981 called...they want their special effects back.
Dave LaRonde
Re: Recreate Effect
on Feb 4, 2019 at 11:16:41 pm
You can pull this off by using a Displacement Map. Make one in a precomp with a solid that has Fractal Noise, Levels and a bit of blur applied to it. If you want to animate it, do it in the precomp.
Then in the main comp, use the precomp as a displacement map for the text layer.
It'll involve some tweaking, but it won't be a horrible amount.
Dave LaRonde
Promotion Producer
Chris Barnes
Re: Recreate Effect
on Feb 4, 2019 at 11:18:39 pm
I'll give that a shot. Thanks!
Michael Szalapski
Re: Recreate Effect
on Feb 7, 2019 at 10:23:12 pm
You don't need to do it in a precomp anymore if you're using a newer version of After Effects. You can simply point the Displacement Map effect at the layer with the Fractal effects, blurs, etc. and tell the Displacement map to use the layer with effects and masks and not just the layer source (it's the second dropdown to the right of the layer picking dropdown).
It makes it easier/faster to iterate on things since you don't have to keep diving into and out of precomps.
- The Great Szalam
Max Haller
Re: Recreate Effect
on Feb 8, 2019 at 4:44:35 pm
you can probably just use the ripple effect. make the wave height and width like around 100 and increase the radius and then you should be able to start seeing it kick in
