Filter to convert RGB pure colors to custom ABC colors?
Cristobal Vila
on Feb 2, 2019 at 5:46:49 pm
Hey, guys.
Do you know if there is an AfterEffects filter that allows you to directly convert RGB colors from an image to other ABC colors defined by the user?
As a picture is worth a thousand words:
I would like to start from an image like the one you see above on the left (where there is a gradient between pure RGB colors) to another image where each of these channels becomes a specific color defined by the user (and can be easily and intuitively modified).
What I show you above is done in AE, in fact, but in several steps: working with 3 layers, using a combination of filters "Calculation" + "Tint", to initially convert each of the channels R, G, and B to pure white, and then tint those 3 whites with my colors A, B and C, to end up merging the 3 layers using ADD modeā€¦
I am very surprised that such a simple thing as this cannot be done in a single stroke, with a filter/effect, in the way of the filter "Tint" or "Tritone"... but no matter how much I look I can't find it...
Any idea?
Big thanks for your feedback! :-)
Cristobal Vila
etereaestudios.com
Oleg Pirogov
Re: Filter to convert RGB pure colors to custom ABC colors?
on Feb 2, 2019 at 11:31:35 pm
Colorama effect can do smth like that:
Cristobal Vila
on Feb 2, 2019 at 11:39:30 pm
Ohh, YES!
Colorama did the trick!
I used lot of times Colorama, but converting from Intensity or Lightness. I hadn't realized that HUE can be used as a starting point.
Thank you so much, Oleg! :-)
Cristobal Vila
etereaestudios.com
