Find and Replace colours in whole project
Harry Hoag
on Jan 31, 2019 at 2:39:22 pm
Hi
Anyone know of a script that will let me find and replace all the colour fields in shape layers throughout a massive project?
Classic client error, been given the wrong colour pallet at the start of the job, now at the end of the job I need to swap around 6 or so stroke and fill colours on a gazillion shape layers through a gazillion precomps. A script would be mighty hand right now.
And ideas would be much appreciated ☺
thanks
H
Oleg Pirogov
Re: Find and Replace colours in whole project
on Feb 2, 2019 at 9:28:13 am
This script substitutes one color for another in all feasible properties (like effects, shapes' fill colors etc) in all comps and layers:
//converts a color channel from [0,1] range to hex string
function channelToHex(channel){
if (channel<0) return "00";
if (channel>1) return "FF";
var channelInt = Math.round(channel*255);
var hex = channelInt.toString(16);
if (hex.length == 1) hex = "0" + hex;
return hex.toUpperCase();
//recursive function to look for color properties; "path" variable is rudimental
function colorSearch(thePropertyGroup, path, targetColor, substituteColor){
for (var i=1; i<=thePropertyGroup.numProperties; i++){
currentProperty = thePropertyGroup.property(i);
//checking, if it's a property and not a property group
if (currentProperty.propertyType == PropertyType.PROPERTY){
//checking, if it's a color property
if (currentProperty.propertyValueType == PropertyValueType.COLOR){
//checking, if color value equals the targetColor (8 bpc) or is its 8 bpc equivalent (16, 32 bpc)
if ([channelToHex(currentProperty.value[0]), channelToHex(currentProperty.value[1]), channelToHex(currentProperty.value[2])].join("") == targetColor){
try{
currentProperty.setValue(substituteColor);
//mostly for handling hidden color layers
catch(err){
else{
colorSearch(currentProperty, path+" -> "+currentProperty.name, targetColor, substituteColor);
function main(){
//dialog window
var dialogWindow = new Window ("dialog", "Color Substitution");
var targetColorGroup = dialogWindow.add("group");
targetColorGroup.alignment = "right";
targetColorGroup.add("statictext", undefined, "Target color:");
var targetColorBoxGroup = targetColorGroup.add("group");
targetColorBoxGroup.spacing = 0;
targetColorBoxGroup.add("statictext", undefined, "#");
var targetColorHex = targetColorBoxGroup.add("edittext", undefined, "FFFFFF");
var substitutionColorGroup = dialogWindow.add("group");
substitutionColorGroup.alignment = "right";
substitutionColorGroup.add("statictext", undefined, "Substitute with:");
var substitutionColorBoxGroup = substitutionColorGroup.add("group");
substitutionColorBoxGroup.spacing = 0;
substitutionColorBoxGroup.add("statictext", undefined, "#");
var substitutionColorHex = substitutionColorBoxGroup.add("edittext", undefined, "0000FF");
var buttonsGroup = dialogWindow.add("group");
buttonsGroup.add("button", undefined, "Ok");
buttonsGroup.add("button", undefined, "Cancel");
var resp = dialogWindow.show();
if (resp == 2){
return;
var prj = app.project;
//converts hex string to [r, g, b, a] color; a = 1
var hexToRGBa = function(hexColorText){
hex = parseInt(hexColorText, 16);
return [hex >> 16, hex >> 8 & 0xFF, hex & 0xFF, 255]/255;
var targetColor = targetColorHex.text;
var substituteColor = hexToRGBa(substitutionColorHex.text);
//searching in every comp...
for (i=1; i<=prj.numItems; i++){
if (prj.item(i).typeName == "Composition"){
currentComp = prj.item(i);
//...and in every layer
for (j=1; j<=currentComp.layers.length; j++){
colorSearch(currentComp.layer(j), currentComp.layer(j).name, targetColor, substituteColor);
main();
Works fine as far as I've tested it.
Harry Hoag
on Feb 3, 2019 at 9:24:07 pm
wow thanks man, I'll give it a go!
Michael Szalapski
on Feb 7, 2019 at 10:25:25 pm
In the future, you might check out Ray Dynamic Color. It's a very handy tool that does this and a lot more.
- The Great Szalam
