Write-On Effect on 2 solid layers, however, only one layer renders
Jamar Bromley
on Jan 30, 2019 at 9:28:54 pm
In our composition, we have two discrete 3D solid layers, each one with a Write-On effect.
The effect works exactly how we want it; however, only one renders at a time in the viewport and in an exported render.
The solid layer that was made first seems favored.
The second one renders only if the first one is turned off.
Has anyone come across this issue / is there a solution to this?
Greg Gesch
Re: Write-On Effect on 2 solid layers, however, only one layer renders
on Jan 30, 2019 at 11:10:37 pm
Hi. Does it still happen if the Brush Positions aren't pickwhipped?
Jamar Bromley
on Jan 31, 2019 at 3:54:13 pm
yup, same thing, only one is rendering
