What are the standard the standard things to fill out the composition settings on AE, i.e preset, pixel aspect ratio etc.
Don Valenzuela
on Jan 30, 2019 at 7:53:34 am
Hi guys, apologies for bothering you. I'm a newbie in using AE and I want to start correctly in doing my project.
Thanks for your professional advice.
Cassius Marques
Re: What are the standard the standard things to fill out the composition settings on AE, i.e preset, pixel aspect ratio etc.
on Jan 30, 2019 at 11:09:44 am
You'll need to answer yourself first. Where do you intend to show of the work you'll be doing in AE?
There is a standard for each standard but even those could vary, Youtube would accept several resolutions. Broadcast varies with location. The list goes on.
Cassius Marques
http://www.zapfilmes.com
Dave LaRonde
on Jan 30, 2019 at 4:22:36 pm
Yes. The animations you make are always based on how they will be used NEXT. How they be played back. They're the delivery specifications.
Dave LaRonde
Promotion Producer
