Keyframe scale rounded rectangle from anchor point (just y axis) and not from the centre
Fabian Biehne
on Jan 24, 2019 at 9:28:44 am
Hi there,
I want to keyframe the scale of a rounded rectangle in the y direction from the anchor which I set to the bottom of the rectangle to preserve it’s roundness and so that it just grows in height. However when I change the y-size under Rectangle Path 1 > Size it still grows from the centre in both y directions (up & downwards). When I go to Transform > Scale (outside of > Contents) and change the y value here the roundness of the rectangle is distorted but the growth from the anchor point works.
Walter Soyka
Re: Keyframe scale rounded rectangle from anchor point (just y axis) and not from the centre
on Jan 24, 2019 at 11:08:30 pm
Instead of using a rounded rectangle, create a path on your shape layer with two points. Add a big fat stroke, set the line cap to to Round, then use Trim Paths to extend it from a circle to a rounded rectangle.
Walter Soyka
Kalleheikki Kannisto
on Jan 25, 2019 at 6:44:09 pm
Walter's is by far the simplest solution. But if you need to do this with a shape layer, you can add the following expression to the Transform Position property of the rounded rectangle. Expression assumes this is is being applied to "Rectangle 1".
content("Rectangle 1").transform.position+[0,content("Rectangle 1").content("Rectangle Path 1").size[1]/2]
Senior Graphic Designer
Fabian Biehne
on Jan 25, 2019 at 6:51:01 pm
Thanks for your help, guys!
