why does the trackmat doesn't work?
Nitai Lev-Oren
on Jan 23, 2019 at 1:47:24 pm
Walter Soyka
Re: why does the trackmat doesn't work?
on Jan 23, 2019 at 2:06:52 pm
You are not using a track matte, you are using the "Preserve transparency" switch:
https://helpx.adobe.com/after-effects/using/alpha-channels-masks-mattes.htm...
Layer 6 will get its transparency from the composite of all layers beneath it, not just layer 7. Since you have only shown a sliver of your Ae UI, we can't see if there are other layers there that may be affecting your composite.
If you want to use a track matte, put the Shape Layer ABOVE your footage layer, then choose "Alpha Matte Shape Layer 1" from the TrkMat column.
Walter Soyka
