Problem when trying to convert stroke effect into a null object position.
Guillaume d'Harcourt
on Jan 17, 2019 at 2:39:09 pm
French here, so I might have made a small amount of writing mistake, sorry...
My issue in video :
Hi all,
I'm trying to create a logo reveal using the stroke effect. So I created my logo using a mask, than add and animate a stroke effect. But I also want a flare at the end of my stroke while the logo outline is revealing itself. So I create a null object, I go on my mask path, copy it and paste it on my null objects position. This create the right animation for my null object, but the sizing is wrong and I can't influence it. Does anyone knows what' I'm doing wrong ?
Thanks a lot.
17 years old french guy, sorry if mistake in my message
Richard Garabedain
Re: Problem when trying to convert stroke effect into a null object position.
on Jan 17, 2019 at 3:58:37 pm
the mask needs to be on a layer that is the same size as the composition at 100% scale. so you might have to re draw it on another layer.
on Jan 17, 2019 at 6:50:10 pm
[Richard Garabedain] "the mask needs to be on a layer that is the same size as the composition at 100% scale. so you might have to re draw it on another layer."
Thanks ! will it work if I create a new layer and just copy/paste the mask ?
Kalleheikki Kannisto
on Jan 17, 2019 at 6:16:44 pm
Scaling the layer results in that problem. You can fix it though: Create a new null object, parent your current null that follows path to it and scale the parent null. Once the right size you can unparent and remove the extra null.
Senior Graphic Designer
