Importing an OBJ Sequence
Stephen Moore
on Jan 14, 2019 at 8:44:35 am
Hi All,
Static OBJs are straightforward but how do you import an OBJ sequence into Trapcode Form in AE?
Cheers
Stephen
Mark Whitney
Re: Importing an OBJ Sequence
on Jan 14, 2019 at 3:16:25 pm
You can import an OBJ model or OBJ sequence with the Base Form pop-up. The objeccts have to be sequentially named though. There should be a sub folder such as: ...\Support Files\Plug-ins\Trapcode\Help\Product Presets\OBJ Files where you can find some samples to play with.
Stephen Moore
on Jan 15, 2019 at 12:13:51 pm
Hi Mark,
Thank you for the reply and... I've cracked it!
Cheers
Stephen
