offset expression question
Nitai Lev-Oren
on Jan 13, 2019 at 9:22:37 am
what does "loopOut (offset)" does?
and what is the difference between loopOut to loopIn property expression?
Nitai Lev-Oren
Re: offset expression question
on Jan 15, 2019 at 9:29:36 am
up
Walter Soyka
on Jan 16, 2019 at 8:12:54 am
An "offset" loop accumulates; it loops the segment you specify, but it offsets the beginning of each loop segment from the end of the last one. A picture might be worth a thousand words:
loopIn() works before the first keyframe (and when you're defining a range, counts keyframes forward); loopOut() works after the last keyframe (and when you're defining a range, counts keyframes backward).
Walter Soyka
Nitai Lev-Oren
on Jan 16, 2019 at 9:26:11 am
thanks, got it!,
but can you explain or give example of the loopIn expression? because I tried it and it doesn't work
Walter Soyka
on Jan 16, 2019 at 12:51:06 pm
Can you show a screenshot or two of what you're trying to do so I can try to explain in the context of your project?
Walter Soyka
Nitai Lev-Oren
on Jan 16, 2019 at 1:24:56 pm
there is 3 keyframes of the red ball one down one up and one down again.
I want to loop it so I placed an expression on the position value:
loopIn(type = "cycle", numKeyframes = 0)
but after the third keyframe the ball doesn't move
here is a video: https://www.screencast.com/t/23SuuXNqvcna
Walter Soyka
on Jan 17, 2019 at 5:08:55 pm
If you want to loop that set of keyframes endlessly after the final keyframe, use
loopOut("cycle");
Walter Soyka
