batch import via CSV file
Antony Dupsta
on Jan 11, 2019 at 10:53:21 pm
Howdy,
I have a data base that includes columns with shot names and paths to those shots. This exports from the data base as a csv file.
Instead of manually importing 100 shots into after effects one by one, can I feed AE a doc that will do a batch import?
Anyone come across something like this before?
Dave LaRonde
Re: batch import via CSV file
on Jan 11, 2019 at 11:54:19 pm
I'm trying to think how that would be more efficient than opening the folder containing the shots, selecting all of them, then dragging them into the AE project pane.
I guess they could be in a bunch of different folders spread out all over hell, but that's no way to work......
Dave LaRonde
Promotion Producer
Mark Whitney
on Jan 12, 2019 at 2:31:09 am
Might OpenSesame do the trick?
https://aescripts.com/pt_opensesame/
Seems like I've seen other csv related utilities, but this is sort of the grandaddy.
Walter Soyka
on Jan 14, 2019 at 2:41:36 pm
This should be pretty trivial to script. What's the format of your CSV data? Can you post a little sample that shows what the CSV export looks like?
Walter Soyka
