Best way to reuse an already rigged character for multiple scenes? (import more than just a reference to a composition)
Noah Shipman
on Jan 11, 2019 at 7:21:09 am
So I have a character all rigged and ready to go, but before I start animating, I want to figure out a way to set him aside so I can use him for multiple scenes without having to go through the rigging process each time.
The only way I can think of doing this is by importing the current AE scene to a new project, and then manually duplicating my character composition as well as my many nested compositions. This becomes entirely too complicated. For example, I have composition "arm" as well as controllers for each puppet pin on arm. I cannot easily duplicate "arm" without replacing the controllers, basically re-rigging.
So what I'm really looking to do is to import not just a REFERENCE to the composition, but the entire composition itself to each new comp/project I create, independent of the original.
Jeff Kay
Re: Best way to reuse an already rigged character for multiple scenes? (import more than just a reference to a composition)
on Jan 11, 2019 at 2:22:40 pm
Create a trimmed down AE project that is just the rigged character w/ subcomps and import that?
Max Haller
on Jan 23, 2019 at 4:42:37 pm
I would think selecting the character comp, save a copy of the project and then go to file> Dependencies> reduce comp. Then youll have all your nested comps too.
or try a script called True Comp Duplicator. I've never used it on a rigged character comp but it's a great time saver when you need to duplicate comps that have a lot of nested elements. It might mess up the expressions on occassion but it generally works really well.
But using a reduced copy of the project it probably the best solution.
