After Effects Puppet tool
Mahmoud Awd
on Jan 7, 2019 at 5:05:25 am
Hi , i wanna make this psd photo have no mesh in the blank area (Like photoshop puppet tool) to animate it properly .
i hope someone help me ASAP .
thanks .
Kalleheikki Kannisto
Re: After Effects Puppet tool
on Jan 7, 2019 at 8:13:58 am
If nothing else works, you can always split it into two layers horizontally at the mouth level (with some overlap between the two layers) and link a couple of puppet pins in the same locations on the two layers to fix the cheeks together.
Senior Graphic Designer
Mahmoud Awd
on Jan 7, 2019 at 1:58:21 pm
Thanks for your respond i'll try it but it seems possible actually, thanks again
