After Effects Expression
Marius Ionasco
on Jan 4, 2019 at 9:31:02 pm
Im having a small problem with an expression in after effects
The Output is Min/Max 0/1
It should do if(Output>0)
v=1080
else v=0
And the shape Layer should change the size
size(x;y) --> (10;v)
Jeff Kay
Re: After Effects Expression
on Jan 4, 2019 at 11:17:15 pm
There is a whole mess of incorrect syntax in this. (What does the error message say?)
The If/Else you are telling it just numbers and it doesn't know what to do with this and will always return an error. Typically something like
if (*expression link*)
v=1080;
else
v=0;
value() is not a argument, inside of AE value [with no parenthesis] will return the keyframed value of the property before any expression has been applied. Value is automatically the same array as the property itself.
If you want to use a variable (I assume you want to use v), it has to be defined and have a value.
I don't know of what Size is a property, but it is an array of 2 and I think that expression is going to return an array of 1.
Try this
var=1080;
else
var=0;
[10,var];
I don't know what that expression links to, but if that value is > 0 this will return [10,1080] and if that value is <=0 then it will return [10,0]
