After Effects CC Purple and Green Video Preview Glitch
Richards Ige
on Jan 3, 2019 at 10:26:08 pm
Hey! I've recently tried to get into editing, and I've already been faced with a problem! :0000
So every time I insert a clip I want to use, the clip in the preview turns purple and green. I don't know why this happens or how to solve it! Can anyone help me?
Jeff Kay
Re: After Effects CC Purple and Green Video Preview Glitch
on Jan 4, 2019 at 4:04:57 pm
I've seen this before with certain video files (and this behavior persists through multiple softwares not just AE). I have not found a workaround for this other than transcoding (which is almost always a good idea). From what I have seen pewviously it has to do with some uncommon settings in the H.264 render itself and a re-render in H.264 will usually fix it (but this will be a second lossy encode, if you are transcoding just use an intermediary codec).
Where and how was the source file generated?
