[AE CC 2018] Working with proxies: little FAQ
Duca Simone Luchini
on Dec 27, 2018 at 1:03:10 pm
Hi everyone,
I'm starting to use footage in 4K and I would like to use Proxi in AE to better manage the limited resources of my PC. So I would have a few preliminary questions about it:
1 - With a comp proxi, the graphics (Shape) and the texts generated in AE will then have the same dimensions and resolutions as the original comp in 4K?
2 - Same thing for vector files imported into AE?
3 - Both tracking (2d or 3D) and - if need be - a subsequent stabilization, should instead be done at full resolution (to take advantage of the higher resolution).
So I wonder if these operations (tracking and / or stabilize) can also be done using the proxi, since they will actually be done at full resolution in the background?
Thanks in advance for an answer.
Duca Simone Luchini
Re: [AE CC 2018] Working with proxies: little FAQ
on Dec 30, 2018 at 8:18:46 am
It is this question really hard...?
It seems no one never used proxies ..., possible?
