how do I do clouds loop?
Nitai Lev-Oren
on Dec 24, 2018 at 2:02:50 pm
when clouds enters the frame and go out in a seamless loop.
(I tried using fractal noise but it looks like steam or something else)
Richard Garabedain
Re: how do I do clouds loop?
on Dec 27, 2018 at 9:42:21 pm
you do one clean cloud animation...then...I dont really know what you are asking...but you do one and then loop it or offset it infinitely
Nitai Lev-Oren
on Dec 28, 2018 at 5:23:46 am
do you know how to do it in particular?
Richard Garabedain
on Dec 28, 2018 at 5:21:17 pm
yeah...you make one cloud and use it as a textured particle then you just animate the clouds coming out...it might be easier to do it in particle world..only because you seem new to after effects....
Do you mean something like this ? https://vimeo.com/manage/20622351/general
just for reference...English is not your first language is it?
Nitai Lev-Oren
on Dec 28, 2018 at 5:24:25 pm
the link is unavailable.
if you know how to do it in particular or you have another tutorial it will be nice to know.
because I searched on you tube and didn't find one
and yes it is not my first language
Michael Müller
on Dec 29, 2018 at 1:06:51 pm
It seems like you have to explain the issue more detailed, as I don't really understand what you are trying to achieve.
Do you have problems creating the cloud? Should it be somewhat realistic?
What is it you want to loop? The clouds changing shape or form?
Michael
Nitai Lev-Oren
on Dec 29, 2018 at 3:00:11 pm
I want it o be realistic but not 2d I want to learn how to create 3d cloud with particular or other effect
Max Haller
on Jan 2, 2019 at 4:34:55 pm
Try checking out this tutorial.
It should give you a decent start at making clouds in particular. I searched for 3d clouds in particular into google and found a lot of results so maybe you can find something that's better suited to your needs.
