After Effects Camera Movement Problem
Trinh Nguyen
on Dec 21, 2018 at 11:08:41 am
I have an issue with camera movement.
I have Element 3d that contains some objects, and I wanna to do a dolly shot so I used 2 keyframes that and changed the value of the X axis.
Problem is the camera stayed still for 1 second before moving, when I check different views, the camera still moves exactly, but the active camera shows a different story... it just happened today, I haven't met this issue before.
Please help.
Kalleheikki Kannisto
Re: After Effects Camera Movement Problem
on Dec 22, 2018 at 7:53:32 am
The first place to investigate would be the graph display of the position animation.
Senior Graphic Designer
Michael Szalapski
on Dec 23, 2018 at 12:44:48 am
Can we see a screenshot of the graph editor as Kalleheikki suggests or a screen recording demonstrating the issue?
Also, what, exact, version number of After Effects are you running?
- The Great Szalam
