Is it possible to subtract a shape from a repeated shape using merge paths
Robert Anderson
on Dec 12, 2018 at 11:42:47 pm
Hi
Is this possible or impossible?
Have created a rectangle with single fill, repeat the object so there are multiple squares.
And I want to use Merge Paths to subtract / intersect another shape from the repeated result.
Any creative solutions or arrangement to the layers that would make this work?
Currently have
GROUP :
  • rectangle
  • repeater
  • fill
  • new path <--
  • merge paths <-- subtract/intersect
have also tried
MAIN GROUP:
SUBGROUP:
  • rectangle
  • repeater
  • fill
  • new path <--
  • merge paths <-- intersect/subtract
subtracting through the repeater seems to see the repeater as an object and then hides everything
any possible ideas that don't involve creating a separate layer with a mask?
Marko Suto
Re: Is it possible to subtract a shape from a repeated shape using merge paths
on Dec 13, 2018 at 3:57:49 pm
Have you tried precomposing the repeated shapes and then applying the mask on the precomp?
Kalleheikki Kannisto
on Dec 15, 2018 at 5:37:56 pm
Depends on what you're trying to do, but making the second rectangle the color of the background would "hide" it.
Senior Graphic Designer
