Why does the "Glow Intensity" do nothing?
Robert Ditty
on Dec 9, 2018 at 7:57:16 am
I have added the glow effect to these vector sun ray shapes from a logo in my video. Here it is with the Glow intensity set to 1.0:
Here it is with the Glow intensity set to 255:
No difference at all. It doesn't matter what parameters I change, it makes no difference. Any help would be a appreciated.
Kalleheikki Kannisto
Re: Why does the "Glow Intensity" do nothing?
on Dec 9, 2018 at 11:15:27 am
I have the feeling that the effect is already pretty much maxed out at 1.0, especially if you're at 8-bit. Does anything happen between 0 and 1? Does changing the glow radius do anything?
Have you tried changing the color depth of the project to 16 or 32 bits? I believe that remaps the slider to a different range and 32 bits might allow going beyond the "full" value.
Senior Graphic Designer
Simon Ubsdell
on Dec 10, 2018 at 11:55:15 am
Your radius is very small. Try increasing it.
Also try using the alpha channel and using A&B Colors.
Simon Ubsdell
tokyo productions
hawaiki
Eric Santiago
on Dec 10, 2018 at 3:10:35 pm
That option has always been about luminance.
You have to be a little more creative with your layers to get that to work.
Simon Ubsdell
on Dec 10, 2018 at 3:18:40 pm
[Eric Santiago] "That option has always been about luminance."
If you use the Alpha Channel instead of the Color Channels and set the Glow Color to A&B Colors it doesn't matter what the "luminance" of your source layer is.
Simon Ubsdell
tokyo productions
hawaiki
