How do I fake light illumination on an actor or object in front of a green screen?
Filip Stillerska
on Dec 1, 2018 at 9:37:34 pm
How do I fake light illumination on an actor or object in front of a green screen? For example, let's say that I've got a talent in front of a green screen holding a fake lightsaber, more specifically a stick that doesn't light up; after I've removed the green screen, added the background and created a laser that replaces the stick I want to make it seem like the blue light from the saber is illuminating the actors face.
Is there a way to do this that gives me somewhat realistic results?
Filip Stillerska
Re: How do I fake light illumination on an actor or object in front of a green screen?
on Dec 1, 2018 at 9:40:28 pm
Example image (this is what I want to achieve): https://pbs.twimg.com/media/DNkG3SKWAAMkGRt.jpg:large
Blaise Douros
on Dec 3, 2018 at 8:16:56 pm
In the example you gave, they definitely used a real light--they used ForceFX sabers on-set for that exact reason, to create realistic interactions with the wielder.
How you do it in post will depend on how much time you want to spend on it. You could probably build a series of masks to simulate facial contours, etc., but I think that's impractical.
What I would do is create a secondary adjustment layer over your actor, post-key, that duplicates and greatly softens whatever Glow effect you're using for the outer edge of the blade. Then, I'd set it to a blending mode like Color, or maybe Screen, and then make sure that it's using your green screen matte so that it doesn't affect ANYTHING on the background. The trick here is that it needs to be set wide enough that it illuminates the actor's face beyond the edge point of the visible lightsaber glow. The idea is that (a) it uses the matte so it's only visible on the actor's face and (b) it starts showing on their face well before the edge of the lightsaber comes anywhere near--so the closer it gets, the more intense the light is.
