rain drops
Ben Peterson
rain drops
on Nov 25, 2018 at 2:01:03 am
What would be the best way to make light raindrops on water effect?
Kalleheikki Kannisto
Re: rain drops
on Nov 25, 2018 at 9:25:24 am
I've successfully utilized Radio waves as an animated texture for Particular for such. Result can be used to drive displacement, glass or other similar effect, depending on how realistic a result you are after. Works great as a bump map converted to normal map for Element, for instance.
Senior Graphic Designer
Ben Peterson
Re: rain drops
on Nov 30, 2018 at 9:08:29 am
Hey Kalleheikki, Sounds complicated. Any tut you know of anywhere? Or if you have time could you please explain more in length? thanks
