Working on cropped clip from premiere
Benjamin de Menil
on Nov 24, 2018 at 3:39:03 am
If i use replace with after effects composition in Premiere, i get threeb items imported into the new AE project: the original clip, a linked comp containing the clip as it was prepared in Premiere, and another comp that contains the uncropped, full length original clip.
I'd like to paint on the clip and only seem to be able to do that on the uncropped comp, which requires searching within it to find the section used in my Premiere timeline.
Next when I'm done is like to replace the clip, which was a proxy, with a color graded version that contains only the section I'm using.
How do i do this?
