Tracking a Plane
Dor Nahum
Tracking a Plane
on Nov 23, 2018 at 11:52:50 am
Hey,
I've been trying to solve this problem for 2 days and can't figure out how to do it properly
I've a scene where I need to track the warning sign of the cigarette box and I want to make it disappear.
The part that I'm touching starting at this frame when the cigarette box's edge appearing
So,
I choose a part from the footage that i can see the whole box,
brush the sign out
mask it
then i went to mocha to track the original clip
export it with AE corner pic motion blur and copy it into the PS png image 1080p as the project settings and this happens
I don't really know if i'm doing this in the proper way ( probably not ), I'm a beginner so don't judge too much ☺
Thank you!
Dor Nahum
Re: Tracking a Plane
on Nov 23, 2018 at 11:57:59 am
I accidentally flagged the guy who responded me while i tried to replay him and it has deleted his message haha sorry
Can you look at my project? because i'm pretty sure that i did what you told me,
when i copy mocha's corner pin to the image, it's scales and rotates the image..
Cassius Marques
on Nov 23, 2018 at 12:28:50 pm
Sure, upload the project. I don't mind.
Cassius Marques
http://www.zapfilmes.com
Cassius Marques
on Nov 23, 2018 at 12:33:22 pm
But by looking at your SS I can see you mistook what I said about it being 1080p. You have to make a distortion of your clean plate to make itself 1080p. Standart corner pin data/usage transformes a 1080p plane into the pins position. copy and paste that corner pin to a 1080p solid and you'll understand what I mean.
Cassius Marques
Dor Nahum
on Nov 23, 2018 at 12:51:25 pm
Yeah, now I understand you. ☺
Do you have an advice how do I make my clean plate itself a 1920x1080?
Maybe I shouldn't even use the mask i've made and use a picture from google?
Cassius Marques
on Nov 23, 2018 at 1:24:48 pm
Use the least amount you'll need. Just paint a feathered dark blue on the botton and adjust as needed to remove the warning, you'll have instant feedback if you open two viewports.
Cassius Marques
Ross Shain
on Nov 26, 2018 at 6:32:19 pm
You can also use the "Align Surface" workflow in Mocha to set your tracked surface to be the full frame. This allows you to create your clean frame at the full frame resolution in context to the frame you want to paint.
This video covers the general workflow. Even though this covers the Insert Module workflow, the same workflow will work with Mocha AE and corner pins.
https://borisfx.com/videos/sign-replacement-with-mocha-pro-align-surface-an...
Ross Shain
Boris FX / Imagineer Systems
https://borisfx.com/products/mocha/
