Tracking a Plane
Dor Nahum
Tracking a Plane
on Nov 23, 2018 at 10:10:13 am
Hey,
I've been trying to solve this problem for 2 days and can't figure out how to do it properly
I've a scene where I need to track the warning sign of the cigarette box and I want to make it disappear.
The part that I'm touching starting at this frame when the cigarette box's edge appearing
So,
I choose a part from the footage that i can see the whole box,
brush the sign out
mask it
then i went to mocha to track the original clip
export it with AE corner pic motion blur and copy it into the PS png image 1080p as the project settings and this happens
I don't really know if i'm doing this in the proper way ( probably not ), I'm a beginner so don't judge too much ☺
thank you!
Cassius Marques
Re: Tracking a Plane
on Nov 23, 2018 at 11:17:43 am
You're doing everything right up to the last point. You just need to have your replace image inside a same size composition as you have tracked in mocha, lets say if your footage is 1080p, create a 1080p comp, place your replace image there and hit ctrl + alt + f (to scale it to comp size). Apply your corner pin to this comp.
Cassius Marques
http://www.zapfilmes.com
