PLEXUS problem - lines flashing up in front of camera
Dominic Burgess
on Nov 16, 2018 at 12:49:14 pm
Hi, so I've had this problem before but I'm so sick of it now that I'm trying to find a solution.
I'm using Plexus 3.0.1.0 to create a really simple 2D grid with points and lines. When I spin around it with my camera I get really thick lines flashing past the cam, as if they are really close to the lens. I don't know why this is as I'm only creating a 2D grid. I've gone through all the settings and I can't figure out what it could be. Attached is an image of what I mean.
Any help much appreciated!
Dom
Cassius Marques
Re: PLEXUS problem - lines flashing up in front of camera
on Nov 16, 2018 at 4:30:09 pm
The latest versions of plexus have built in camera cut off properties. Use that. You have to enable the checkbox that enables DOF to see them. You'll be able to limit the near vanishing points.
Cassius Marques
http://www.zapfilmes.com
Dominic Burgess
on Nov 16, 2018 at 7:51:50 pm
Ah ha! Yes! Thankyou! Found the checkbox, so simple! Thank you!
