Traditional moving texture
Alexander Solowiow
on Nov 15, 2018 at 2:36:08 pm
Hi.
Does anybody know how to make this moving texture in After Effects? I found this gif on Deviantart and the creator of it is not responding to me.
I can't find anything on YouTube either. https://orig00.deviantart.net/77da/f/2018/059/4/3/sam___by_maskman626-dc4j4...
Thanks in advance,
Cheers.
Kalleheikki Kannisto
Re: Traditional moving texture
on Nov 15, 2018 at 2:45:33 pm
In general terms you have three versions of the texture painted and loop them. For a simple approach you could do a looped precomp that is overlaid (in Overlay mode) over the entire comp so as the get the same effect everywhere.
Senior Graphic Designer
Max Haller
on Nov 15, 2018 at 3:20:01 pm
You can try playing with animated noise overlays, or setting the blend modes to the line layers as dancing dissolve. Blurring the edges can help make more noise show up too.
Alexander Solowiow
on Nov 16, 2018 at 1:54:03 pm
Can you go into details more of how this can be done? I'm an occasional After Effects user.
