Black screen after rendering
Guram Gigauri
on Nov 13, 2018 at 4:57:20 am
Hello, I have installed after effect 2019, made some video and began rendering in quicktime (there is no H264) after rendering the video there is only black sreen and music sound, no image or video.
what is wrong does anyone know?
thanks
Dave LaRonde
Re: Black screen after rendering
on Nov 13, 2018 at 5:04:58 am
You made all your layers into Guide Layers, which don't render out. Without useful information, that's my best guess.
Dave LaRonde
Promotion Producer
Guram Gigauri
on Nov 13, 2018 at 7:03:55 am
I will show you later the screenshot, I don't know what does this guide layer means
Guram Gigauri
on Nov 13, 2018 at 2:57:28 pm
look at the picture please and tell me what is wrong
thanks
Jay Bautista
on Nov 13, 2018 at 4:39:35 pm
I may need to know you render settings.
But the best solution I can think of right now is you need to have Adobe Media Encoder so you can render your video in H.264
Guram Gigauri
on Nov 14, 2018 at 5:12:25 am
I have installed adobe encoder, but there is still no h264
Dave LaRonde
on Nov 13, 2018 at 6:09:24 pm
Why is the Solo switch activated on all your layers?
Dave LaRonde
Promotion Producer
Guram Gigauri
on Nov 14, 2018 at 5:13:34 am
there is no matter if it is activated or not, I try both
Guram Gigauri
on Nov 14, 2018 at 6:32:14 am
here is the error message
Jeff Kay
on Nov 14, 2018 at 5:27:47 pm
What is the deliverable format?
What formats have you tried?
Is there a format that will successfully push out the video?
Has everything you tried been a subset of quicktime?
A lot of support has been pulled from quicktime. If you really want to to have a particular codec in a .mov and it isn't a direct render option, then push it out in whatever container it can be and then rewrap it as .mov.
Dave LaRonde
on Nov 14, 2018 at 5:49:36 pm
I recommend that you do not use AE CC 2019. Instead, use AE CC 2017. You can have both versions of Creative Cloud on your machine.
For most users, CC 2017 is far more reliable than CC 2019. Those who are using it successfully tend to be 20-year users of Adobe software or extremely knowledgeable of computers. If you are neither of these, spare yourself a lot of grief and use something that actually works.
Dave LaRonde
Promotion Producer
Walter Soyka
on Nov 15, 2018 at 10:59:38 am
So you're rendering to QuickTime, with Animation as your codec? I don't think that the native Windows media player has an Animation codec decoder. Unless you install a viewer that can read these files (VLC is a good one), the media may appear black.
Installing Adobe Media Encoder does not make H.264 available in the After Effects render queue. You must either render to an intermediate file from Ae and then compress that file to H.264 in AME, or your must add your Ae comp to AME (either via drag and drop, or via the Queue in AME button in Ae's render queue). Then, you can choose H.264 as a format and get MP4 files as your output.
Walter Soyka
