Particular – Particles are offset from path
Benedict Hein
on Nov 9, 2018 at 9:37:33 am
Hi there,
pretty new to particular.
I am trying to have my emitter/particles follow a path. Looks fine so far, but whatever I do the whole thing is emitted sligthly beneath the path.
Any offset or other position options are on "0". Any Ideas?
Thank you and regards!
Kalleheikki Kannisto
Re: Particular – Particles are offset from path
on Nov 9, 2018 at 10:00:22 am
Two things seem apparent:
1) There seems to be some sort of positional smoothing going on. Did you start with a preset? Check the emitter position accuracy setting (don't remember the exact name of the property); the options are something like 1, 1/10 and precise.
2) If the path and reference image are 2D and you have a 3D camera, any movement of that camera will offset the path. You can try creating a new camera or moving the existing one if this is the case.
Senior Graphic Designer
Benedict Hein
on Nov 9, 2018 at 10:23:20 am
I found "Position Subframe" Linear/Smooth/10xSmooth etc. which didn't change anything.
But actually I did not have a camera set up. Did that now and adjusted some settings, which worked. Perspective seems fine now.
Thank you!
