How does After effects know that SBON7492000H is a subaru outback?
Richard Garabedain
on Nov 5, 2018 at 10:33:28 pm
I searched my project window for Outback and it brought up only 1 clip...SBON7492000H.mov Now when i go look at the clip it does say subaru outback footage at the start of the clip..But there are no folders labeled outback or subaru in my project window...really there is no way it should know...so how does it?
Andrew Somers
Re: How does After effects know that SBON7492000H is a subaru outback?
on Nov 6, 2018 at 6:52:53 am
Metadata or Path information. In the Finder, is it in a folder named Outback? If you look at the metadata is there a field that says Outback?
Andrew Somers
VFX & Title Supervisor
https://www.GeneralTitles.com
Eric Santiago
on Nov 6, 2018 at 2:12:21 pm
It's in the meta tag.
We do it all the time.
Richard Garabedain
on Nov 6, 2018 at 3:13:37 pm
I did not see any meta tag information. IM on a pc. But I did try a experiment. I created a folder named youtube when i imported from that folder it also showed up when i searched for youtube
Andrew Somers
on Nov 7, 2018 at 10:22:43 am
Meta and/or path (i.e. folder) what utility did you use to look at the metadata?
Andrew Somers
