Renaming items with scripts
vahab san
on Nov 5, 2018 at 7:06:04 pm
Hello everyone
Here is the situation:
- I have an expression in comp A referring to comp B;
- If I change the name of comp B from the project panel manually, expressions will update automatically;
- If I change the name of comp B from the project panel by scripts, expressions will not update.
How can I rename the comp B with script and expressions update automatically?
Cheers
Walter Soyka
Re: Renaming items with scripts
on Nov 5, 2018 at 8:23:28 pm
Try it like this:
var originalCompName = "Comp B";
var newCompName = "Comp C";
myComp.name = newCompName;
app.project.autoFixExpressions(originalCompName, newCompName);
Walter Soyka
Walter Soyka
on Nov 5, 2018 at 8:57:20 pm
And to clarify what it does... autoFixExpressions(oldText, newText) will identify all broken expressions, do a search and replace within them (swapping out oldText for newText), and committing that change if it fixes the break.
Walter Soyka
vahab san
on Nov 6, 2018 at 8:07:34 am
Walter
Thank you very much.
Worked perfectly. And again thank you for the explanation.
