The Photoshop Library operation failed because the selected area is empty
Vladislav Macíček
on Nov 5, 2018 at 2:34:40 pm
Hey, guys. I'm working on a shot and suddenly this message appeared and I can't view or render the first frame.
I'm using 1 PS file (image sequence imported as footage), so I assumed the PS file was causing the issue, but when I double-click it in AE or open the PS it's all fine. I tried to render the PS and switch it, didn't work. And even if I uncheck the visibility of the PS it still doesn't work. All other frames are working.
I'm also using quite a few .png sequences, I'm not sure if those use PS library somehow, idk. The weird thing is that it happened suddenly, I haven't touched the PS layer, was only adjusting effects on other layers.
Just got the shot approved before the full res render, so I'm really pissed off. I have no clue what's wrong, any help appreciated.
Thanks, Vladislav
Vladislav Macíček
Re: The Photoshop Library operation failed because the selected area is empty
on Nov 5, 2018 at 4:03:38 pm
OK, that was weird...
I found out that 'Median' on a different layer was causing it. Just switched it to 'Median (Legacy)' and it works, lol.
Vladislav Macíček
on Nov 5, 2018 at 4:07:09 pm
But overall the new iteration of effects seems little buggy. For example I had some alpha problems with the remade 'Gaussian Blur'.
You should look into it, Adobe.
Steve Ogden
on Apr 17, 2019 at 7:49:25 pm
OOOH! Yeah, that's a doozy of a bug. Thank you!!! - I spent all morning troubleshooting failed renders.
And sure enough removed the Median effect and it worked fine.
I'm adding a note to this thread, that when rendering it in media encoder I would get the message:
"Encoding Failed ---------- The Operation was interrupted by user"
(which I did not)
Though when rendering it in AE I got the Photoshop Library Operation failed message.
I'm having this problem in AE 2019 16.1.1 - so it's pretty lame that hasn't been fixed. I'll submit a bug report.
PS: Depending on what you're using media for, a fast blur, then a levels, clamping the alpha channel works
imac 27" on Mojave, AE 16.1.1 and ME 13.1.something
