How to maximize battery usage
Xavier Paredes
on Oct 31, 2018 at 8:10:30 pm
I'm catching a plane tonight for a long flight and would like to wok while on the plane. Besides quitting all apps that I am not using, are there any other tips/tricks that can help prolong my battery charge?
I know that many processes run in the background so I wonder if there's any way to limit or quit them altogether? I will also make sure my screen brightness is just bright enough so as to save battery.
Thanks for any tips!
- Xavier
Xavier
Blaise Douros
Re: How to maximize battery usage
on Oct 31, 2018 at 8:18:05 pm
Check under your seat--a lot of planes have AC outlets now.
Xavier Paredes
on Oct 31, 2018 at 8:23:00 pm
Thanks. I did not know that!
Xavier
Andrew Somers
on Nov 1, 2018 at 5:08:31 am
I'd be surprised if a long flight didn't have AC outlets, so you should be okay, BUT, to answer your question regarding quitting processes:
You can use ACTIVITY MONITOR in the Utilities folder to look at what processes are running, which are using the most energy/CPU/Memory etc, and you can also force them to quit.
Andrew Somers
VFX & Title Supervisor
https://www.GeneralTitles.com
