Perfect aligned masks
Billy Rodgeers
on Oct 29, 2018 at 1:57:52 am
I want to break up a clip into multiple masks( for a kind of glass break effect), but I was curious if there is a way I can break them up so the edges align perfectly. With the pen tool there will still be some inconsistencies. Can I use some sort of alpha matte? Is there any way to snap them together? Thank you for any responses.
Kalleheikki Kannisto
Re: Perfect aligned masks
on Oct 29, 2018 at 1:10:57 pm
Drawing them in Illustrator and pasting into AE is the easiest solution.
Senior Graphic Designer
Billy Rodgeers
on Oct 29, 2018 at 2:56:19 pm
I tried that, but there was an issue with pasting them in. It'll paste the mask shapes in, but it always pastes them in the center of the comp, not in whatever position it was in the illustrator project. This isn't too big of an issue, but it would be better if it could be solved.
Richard Garabedain
on Oct 29, 2018 at 3:41:37 pm
is the iilustrator file size 1920x1080
Billy Rodgeers
on Oct 29, 2018 at 4:30:52 pm
Yes
on Oct 30, 2018 at 4:58:15 pm
Copy and paste them all at once to one layer, and they are aligned. If you need to separate them out to individual layers, you can copy and paste individual paths to new layers in AE. I suspect there's a script in existence that splits them all in one go as well.
grinner hester
on Nov 2, 2018 at 12:30:09 am
duplicate the layer, then alt-drag a new source onto the new layer then just move it one axis to stack.... then repeat as needed.
Hafeez Zainalabidin
on Oct 31, 2018 at 5:23:33 am
Or if you have some coin to spare, you could get the Overlord plug-in from BattleAxe: https://www.battleaxe.co/overlord/
I use it a lot because I work closely with illustrators and it's been a dream to transfer their artwork into AE and have them fit just as intended in the frame.
*full disclosure: this isn't a sponsored post.
Billy Rodgeers
on Oct 31, 2018 at 5:26:46 am
That certainly seems like a good investment. Thank you for informing me of it.
Michael Menefee
on Nov 1, 2018 at 3:03:52 pm
Can't you simply import the illustrator file as a comp and maintain layer size when doing so?
Ross Shain
on Nov 1, 2018 at 4:07:11 pm
If you use the Mocha AE bundled with After Effects for masking, there is the "Attach Layers" tool that was made for this purpose. Each layer can have its own tracking and animation, than you can link the points at edges together.
If you are using the new Mocha AE 2019, you find "Attach Layers" tool in "Classic" workspace.
Ross Shain
Boris FX / Imagineer Systems
https://borisfx.com/products/mocha/
Mark Doctor
on Nov 1, 2018 at 11:07:59 pm
Almost sounds like the old AE shatter effect. I suggest you check it out☺.
Greets Mark
Billy Rodgeers
on Nov 2, 2018 at 12:35:03 am
Absolutely. I just want to be able to section off the prices and add a drop shadow for a more 3d effect. This was my first thought. Idk if any of you know anything about if possiblly using cinema 4D could have a more efficient solution, or if there's a better way in after effects.
