how do i separate X & Y on the scale parameter?
Nitai Lev-Oren
on Oct 28, 2018 at 9:03:42 am
how do i separate X & Y on the scale parameter, because I can't bend the keyframes?
Nitai Lev-Oren
Re: how do i separate X & Y on the scale parameter?
on Oct 28, 2018 at 9:25:27 am
Mark Doctor
on Oct 28, 2018 at 2:37:06 pm
X,Y and Z, it only works on 3D-layers. So make it 3D first.
Greets Mark
Nitai Lev-Oren
on Oct 28, 2018 at 2:42:34 pm
if i unchain the chain I can separate them but still I don't have 2 handles.
I have one, and in 3d layer also I have one handle.
see pic
Mark Doctor
on Oct 28, 2018 at 4:10:17 pm
Ah i see the problem, im not near an AE-workstation currently, but if a direct solution is needed:
Add 2 sliders from expression control to your layer and pick whip x to one and y to the other. After that you can add both slider value's to your graph-editor.
Array's in AE don't have separate value's in the graph editor. That's the reason for the separated (position) dimensions.
Nitai Lev-Oren
on Oct 28, 2018 at 4:23:23 pm
why there is this on the position and you can seperate the X and Y and the scale you can't?
Mark Doctor
on Oct 28, 2018 at 5:50:46 pm
For the true reason you should now why array's are used. That's a lot of computer science and in the end you probably agree the way it is 😉
(Enemy of the state)
Fiedler: The satellite is 155 miles above the Earth. It can only look straight down.
Jones: That's a bit limited, isn't it?
Van: Well, maybe you should design a better one.
Nitai Lev-Oren
on Oct 28, 2018 at 5:53:38 pm
yea you probably right, thanks for the answer about the slider.
