how do i seperate X & Y on the opacity parameter?
Nitai Lev-Oren
on Oct 25, 2018 at 12:56:10 pm
the speed graph points is hard and I can't loosen them like the position if I separate X and Y
Steve Bentley
Re: how do i seperate X & Y on the opacity parameter?
on Oct 25, 2018 at 1:03:04 pm
Would changing to a velocity graph help? You can do that here in the curve editor.
I'm not sure I understand the reference to opacity - it only has one attribute but yes you can change the curve on that in the curve editor. Opacity is just a number between 0 and 100 so it doesn't have an x or y. The position the point has on the curve is just the value mapped against where keyframe is in time.
Nitai Lev-Oren
on Oct 25, 2018 at 1:08:45 pm
The problem was I can't do a U shape parabola that is symmetric or not, but you help me and I changed it to the
value graph on the button you said and now I can.
John Heiser
on Oct 25, 2018 at 2:33:38 pm
Change your keyframes from linear to Bezier, and the proper handles will appear in the graph.
John Heiser
Senior Editor
o2 ideas
Birmingham
