Extraperlate constant movement before and after keyframes
Mike Futcher
on Oct 25, 2018 at 10:11:39 am
Hello After Effects people.
I'm new to after effects, though I'm an experienced 3D animator with Blender.
I'm creating a video that will contain a lot of images scrolling past at a constant rate. From what I understand I can create a null and parent everything to it, but... is there a way I can set two keyframes - say at position 1 at frame 100 and position 2 at frame 200 and have the null move at the same constant rate both before frame 100 and after frame 200?
Thanks in advance,
Mike
Walter Soyka
Re: Extraperlate constant movement before and after keyframes
on Oct 25, 2018 at 2:34:03 pm
You can use an expression. Alt+click on the stopwatch icon for the position property, then paste in this code:
if (numKeys > 1) {
if (time < key(1).time) loopIn("continue")
else loopOut("continue");
} else value;
Walter Soyka
Mike Futcher
on Oct 25, 2018 at 4:45:17 pm
Wow - I didn't think I'd be entering code so early, but you've explained very clearly how to do it - thanks!
