Smooth Edges on Turbulent Displacement Effected Shape
Sam Miles
on Oct 24, 2018 at 12:38:59 pm
Hey Guys I have applied a turbulent displacement effect on a circle and animated it.
Now the edges of my shape are jagged.
any idea how to get it to smoothen out for a clean edge?
Jeff Kay
Re: Smooth Edges on Turbulent Displacement Effected Shape
on Oct 24, 2018 at 4:29:27 pm
I can't replicate this unless I crank up the complexity. Try taking the complexity down (if its this, then it is not a jagged edge you are seeing, it is the increasingly finer adjustments due to increased complexity).
Steve Bentley
on Oct 24, 2018 at 10:33:05 pm
Also try increasing the bit depth of your project. If you want to upload the project we can take a look.
Sam Miles
on Oct 25, 2018 at 8:20:28 am
Cheers guys,
I think I found out the problem! It was the Colorama effect that was creating the Jagged edges.
So i deselected mode alpha in the settings and it worked a charm.
appreciate your help apologies if I wasted your time.
