How to stretch a few layers on timeline?
Russell Black
on Oct 23, 2018 at 1:32:19 pm
Is it possible to stretch several selected layers so that they do not overlap one another and be placed one after another? Or I need to calculate the duration each time. Divide the length of the composition into 4 text layers in this case. It takes a lot of time.
P. S.: I know about the "Keyframe Assistant" but it works a bit not as I need it. It saves the length of the layer, and I need the layers to fit in the length of the composition. For example, I have 4 layers and composition for 20 seconds, so I need that each layer becomes 5 seconds. And the "Keyframe Assistant" works like this: 4 layers stack one after another, and goes beyond the composition, that is, 4 layers * 20 seconds each = 80 seconds.
Also I can Pre-compose and time remap, but it's so difficult to navigate with transitions, etc.
Is there an option I do not know about?
Thank you!
What I have in the beginning
What I have when stretch few layers:
What I need:
